which 2.5 motor would be best for turbo setup
mazda_55
Post by mazda_55 »
im just trying to figure out which motor would be best to turbo cuz i want to at least run a 14 in my mx and i would really like to use the t3/t4 turbo any suggestions or anything cuz i went to the races this weekend and there was an mx-6 there with the klze motor and it was turbo and it was doing low 13's but just any input on this at all would be great thnx
Hy300
Re: which 2.5 motor would be best for turbo setup
Post by Hy300 »
Drop in a KLZE, tune it properly and get the right ECU, put in 2.5L headers and adapt your exhaust for the extra length. You should run 14's on that alone. Put in the usual engine modifications, cams, TB, ported IM, headwork, valve job, etc. You should get into 13's with a lightened MX-3 without problems.<p>It just takes time and money.
Zoso124
Post by Zoso124 »
KL-DE or some call it the KL-03.
Mike Evans
Gone:
jbreese00
Post by jbreese00 »
the KLDE and KL03 are not the same engines. The KLDE is a 2.0L not sure from what car, but the KL03 is from American/Canadian MX6, Probe, 626, etc. As far as turbo, in general the lower the compression the easy/safer it is to turbo, hence more people would use the lower compression KL03 which has a compression of i believe 9:1 at ~165hp rather than the Japanese KLZE which yields 10:1 at ~195HP however like previously stated, and properly maintained KLZE will give you more power. Hope this helps
Thank You, Justin
'92 MX-3 GS
Huh? This is that i thought<p>KLDE: ASPEC 2.5L, 9.2:1 Compression, ~185hp
KLZE: JSPEC 2.5L, 10:1 Compression, ~200hp<p>According to what i understand is that running a KLDE turbo, you can have more boost than the KLZE, but all your doing is making up for the lesser compression of the DE, plus a bit more power. Although you will run less boost on a KLZE than a KLDE, you should get more power in the end with a KLZE<p>[ May 19, 2003: Message edited by: Nd4SpdSe ]</p>
lazzyie
Post by lazzyie »
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by JBreeseMX3:
the KLDE and KL03 are not the same engines. The KLDE is a 2.0L not sure from what car, but the KL03 is from American/Canadian MX6, Probe, 626, etc. As far as turbo, in general the lower the compression the easy/safer it is to turbo, hence more people would use the lower compression KL03 which has a compression of i believe 9:1 at ~165hp rather than the Japanese KLZE which yields 10:1 at ~195HP however like previously stated, and properly maintained KLZE will give you more power. Hope this helps<hr></blockquote><p>KL-DE is the same as a KL-03. The compression ratio is 9.2:1 or 9.6:1 if you get an early 1993 motor. The K8 that the Mx-3 has would be a great turbo motor in my opinion as well. Could put down less torque that the 2.5 liters and still have a good amount of hp. Less broken axles and such. Also you already have this motor. Good luck.<p>[ May 19, 2003: Message edited by: lazzyie ]</p>
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
pelado
Post by pelado »
the KLDE and KL03 are not the same engines. The KLDE is a 2.0L not sure from what car, but the KL03 is from American/Canadian MX6, Probe, 626, etc. <hr></blockquote><p>I wish to echo the statements that imply this guy doesn't know what he's talking about. KL is the designation for a 2.5L engine V-6 engine. KJ is a 2.3L, KF is a 2.0L, K8 is a 1.8L.
Period. End of discussion.
Buff1110
Post by Buff1110 »
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by pelado:
<hr></blockquote><p>and the kl03 has 164 hp not 185
Dan
92 Mx-3 Gs, KLZE Powered!! - SOLD!!!!
02 Tacoma TRD - Daily
93 Honda del Sol - New Project
IanL
Post by IanL »
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Buff1110:
<p>and the kl03 has 164 hp not 185<hr></blockquote><p>Except the 95-97 Millenia (170 hp)<p>and the 98 MX-6, 626 and Millenia (all 170 hp)
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system :)
