Too bad we cant get rid of the vaf
jamik_69
Re: Too bad we cant get rid of the vaf
Post by jamik_69 »
cant you get the hks vpc
"guess i forgot to put the foglights in"
mx3man83
Post by mx3man83 »
what is that?
My Cardomain site
jamik_69
Post by jamik_69 »
The HKS VPC is designed to physically and electronically replace OE air metering devices which present a significant restriction to the intake system and offer no adjustment or reprogramming options to take advantage of dramatically higher air flow or larger fuel injectors. The VPC converts both air flow meter and air mass sensor systems to what is called a speed density system by utilizing a 16 bit central processing unit reading its own intake air temperature sensor and absolute pressure transducer (B-MAP sensor) signals. This unique conversion feature not only allows the VPC to replace the factory air flow metering devices, but also eliminates the need for a fuel cut defencer. Another benefit of the VPC is the ability to create programs to take advantage of larger fuel injectors and new air flow characteristics (larger turbos). In some specific instances, the VPC may be used in addition to the PFC F-CON and larger injectors for the ultimate in HKS plug-in fuel system technology. VPC equipped vehicles respond quicker with improved horsepower.
mx3man83
Post by mx3man83 »
well where the heck do u get one of those?
My Cardomain site
