engine check light.....kinda :)
ok i just recently bypassed the coolant lines that went to the little intercooler looking thing that behind the center counsel in the cooling our heating unit(sorry dont know the name)..because i toook that whole thing out. any way...after i did that , when i drive at high way speeds the check engine light comes on....but when i take a tad bit of pressure of the gas(just a little bit) it will go away...it might come back in 5 mins our it might take 2 hour for the check engine light to come on...but if i let of the gas it goes away...what can this be ???? thanx for help [img]shrug.gif"%20border="0[/img]
Re: engine check light.....kinda :)
could be 02 sensors going<p>[ September 30, 2002: Message edited by: lazzyie ]
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi
96 Integra LS DD
91 Crx Si drag car
Man, you took out your heater? I live in South Florida and I STILL wouldn't do that. But then again, I'm a wuss when it comes to the cold. Specially when getting in a freezing cold car. <P>I hate heat too and I couldn't live without A/C, but at least I could open the windows to help somewhat when the car's moving.
I have the exact same symptoms and I pulled a code 17 and 24 (and 5 but thats unrelated I think) 17 and 24 are for the o2 sensor, left and right o2 inversion....which I think means they are no good. did you jump the diagnostic to get the codes?
Tom Alexander
no i did not......how do i go about doing that if u dont mind
Its listed under the V6 FAQ, you will have to select "show all topics"
