2.5 Manifold w/2.5 TB on1.8?
Can this be done? Power increase? anyone done it?
Re: 2.5 Manifold w/2.5 TB on1.8?
The 2.5 injectors with the 2.5 ECU might be a performance boost but I don't know about the rest of it. <P>I believe somebody put a Millenia intake on a 1.8 but I can't remember who. Luc Tremblay maybe?
- masonholmes
This was discussed somewhat on the mailing list and Probetalk. Would most likely would make for a rich running setup and bad VRIS points.. Anybody else got any input here?
1993 MX-3 ~ SE * 2.5L Swap'd
1993 RX-7 ~ Rotary Performance Built
1996 MX-5 ~ M-Edition * Topless, Daily Driver
masonholmes@hotmail.com
I think it would be more HP becuase the TB is larger(more air) the runners are larger(more air) the the injectors flow more(more fuel)<BR>More air more fuel more power?
- mrspanky79
I just put the 2.5 injectors on to the 1.8 before i headed down to carlisle and i will tell you its a big loss in power. Watching all my gauges it gets way to rich around 3000rpm and then you will start getting your engine light comming on. And flooring it feels like you are trying to take off in 3rd
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
- Custommx3
- Site Administrator
Who were u @ carlsile? Did I meet you?
- mrspanky79
Yes you did. Im Dave the mica blue mx3.
99 vitara 4x4
99 vitara 4x4
- Zoso124
no difference in runners. i have just put on the KL manifold but it is warped. when i get it milled down or sealed up some how I'll let you know my findings.<BR> <A HREF="http://www.premiercompacts.com/shows/cc ... ge1663.jpg" TARGET=_blank>http://www.premiercompacts.com/shows/cc ... 663.jpg</A>
Mike Evans
Gone:
Gone:
what difference in sizing exists between K( and KL injectors?
European Mx3 GsRT
