2.5 Manifold w/2.5 TB on1.8?
Stevekowalchuk
Post by Stevekowalchuk »
Can this be done? Power increase? anyone done it?
pelado
Re: 2.5 Manifold w/2.5 TB on1.8?
Post by pelado »
The 2.5 injectors with the 2.5 ECU might be a performance boost but I don't know about the rest of it. <P>I believe somebody put a Millenia intake on a 1.8 but I can't remember who. Luc Tremblay maybe?
masonholmes
Post by masonholmes »
This was discussed somewhat on the mailing list and Probetalk. Would most likely would make for a rich running setup and bad VRIS points.. Anybody else got any input here?
1993 MX-3 ~ SE * 2.5L Swap'd
1993 RX-7 ~ Rotary Performance Built
1996 MX-5 ~ M-Edition * Topless, Daily Driver
masonholmes@hotmail.com
white fish
Post by white fish »
I think it would be more HP becuase the TB is larger(more air) the runners are larger(more air) the the injectors flow more(more fuel)<BR>More air more fuel more power?
ZUNE MX-3 Gs
Post by ZUNE MX-3 Gs »
both manifolds are the same high?
BE FAST!!!
mrspanky79
Post by mrspanky79 »
I just put the 2.5 injectors on to the 1.8 before i headed down to carlisle and i will tell you its a big loss in power. Watching all my gauges it gets way to rich around 3000rpm and then you will start getting your engine light comming on. And flooring it feels like you are trying to take off in 3rd
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
Custommx3
Site Administrator
Post by Custommx3 »
Who were u @ carlsile? Did I meet you?
mrspanky79
Yes you did. Im Dave the mica blue mx3.
99 vitara 4x4
ZUNE MX-3 Gs
what about installing only the runners?
BE FAST!!!
Zoso124
Post by Zoso124 »
no difference in runners. i have just put on the KL manifold but it is warped. when i get it milled down or sealed up some how I'll let you know my findings.<BR> <A HREF="http://www.premiercompacts.com/shows/cc ... ge1663.jpg" TARGET=_blank>http://www.premiercompacts.com/shows/cc ... 663.jpg</A>
Mike Evans
Gone:
BATTOSAI
Post by BATTOSAI »
what difference in sizing exists between K( and KL injectors?
European Mx3 GsRT
