KL-03 swap
KL-03 swap
Is the KL-03 any bigger than the 1.8L and how hard would it be to swap. How much would it cost for a Kl-03? It's rated at 170hp right.<P>Thanks<BR>Larz
Re: KL-03 swap
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by larz13:<BR><B>Is the KL-03 any bigger than the 1.8L and how hard would it be to swap. How much would it cost for a Kl-03? It's rated at 170hp right.<P>Thanks<BR>Larz </B><HR></BLOCKQUOTE><P>Larz, the KL-03 engine is a 2.5L. I haven't done the swap myself yet, but i've heard its relativly easy, its a stright bolt up, I beleive. Im not totally sure about the price, but im sure you could pick one up for less then $600USD or so. The KL-03 engine is rated at 160, i beleive.<BR>
jonnybpimpin
Re: KL-03 swap
KL-03:<P>Mazda 626 & MX-6 - 1993-97 <BR>Ford Probe GT - 1993-97 <BR>162 to 167hp @ 5600 to 6000 rpm (*), CR 9.2:1 <BR>(*) Varies from one model to another<P>KL-ZE is to be found ONLY in J-spec cars (ie. Right hand drive, Japan and Australia, maybe imports in UK)<P>Eunos 800 (Mazda 626 & MX-6) - 1998+, Only in Japan <BR>Xedos 9 (Mazda 929 & Millenia) <BR>200 hp @ 6500 rpm, CR 10:1 <P><BR>i hear the kl 03 is straight bolt on. <BR>but the kl ze is a little harder. and more money
Re: KL-03 swap
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by jonnybpimpin:
KL-03:<p>Ford Probe GT - 1993-97 This is the one I am getting......
(*) Varies from one model to another<p>i hear the kl 03 is straight bolt on.
but the kl ze is a little harder. and more money<hr></blockquote><p>When u say a straight bolt on, is that for the 4cyl or the v6?? I have the 4cyl and a KL-03 engine...u recommend a swap or just find a turbo for my currant????
Please really need help.....
For every action there is a re-action!
mazdamxstyle
Re: KL-03 swap
Way to much work to go from a 4-cylinder to the v6 KL-03 look for a turbo if you want more power or look into the 4banger swap.
1993 Mazda mx-3 GS - Blaze Red (Totaled) Went through an 89 rx7 and a 93 del sol. Now searching again!
http://www.cardomain.com/id/mxmisl
- Zoso124
Re: KL-03 swap
No such thing as a KL-03, proper term is KL-DE.
Mike Evans
Gone:
Gone:
MazdaManiacMx3
Re: KL-03 swap
Turbos are nuts , You run out of things to do and costs much more money for a normally aspirated engine. Turbos are exspensive but the upgrades are much cheaper to upgrade , and you can make massive power with a turbo .
93 Kandy Tangerine Mx3 GS-DE
02 Subaru Impreza OBS
& Lots of Toys to haul
mightym0use5
Re: KL-03 swap
I agree with mazdamaniac - except that a NA engine is more dependable than a non-stock turbo engine - which is only if the engine did not come with a turbo in the first place.
MazdaManiacMx3
Re: KL-03 swap
Yes because engines with turbos stock are tested for 2 years before they can even be released onto the market so the maufacturer works out all the bugs for us .
MazdaManiacMx3
Re: KL-03 swap
Turboing a KLZE is twice the work and twice the money . You have to get everything custon made.
Kris
Kris
Re: KL-03 swap
what do you mean double the work and money? It should be the same work at turbo-ing a K8? They're basicly the same engine in the way of layout, the only thig thats different is the internals...right?<p> <blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by jonnybpimpin:
but the kl ze is a little harder. and more money<hr></blockquote><p>KLDE and the KLZE are basicly the same, except for different heads, pistons, cams, no egr, all the internal stuff, if you look at each engine, unless you look at the internal or the stamping of the codes on the parts, they would/should identical, its just that the ZE engine itself costs more becuase of its demand<p>FYI, its not called a KL03, there's no such thing, its called KLDE, i believe that KLO3 referes to the stamping on the cams on KLDE engines, but for some odd reason, people call them KL03's instead of KLDE's<p>[ September 05, 2003: Message edited by: Nd4SpdSe ]</p>
Gro Harlem
Re: KL-03 swap
This thread is over 2 years old!! wtf
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Spydie
Re: KL-03 swap
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Gro Harlem:
This thread is over 2 years old!! wtf<hr></blockquote><p>
lol
lol
