Advanced timing
Advanced timing
Hello<P>I am thinking about modifing my v6 by advancing the timing . <BR>Do I also need to buy a new chip?<P>thx<P>------------------<BR>shawnm<BR>MX-3 red blaze...POLAND<BR>UIN 21934953<BR>shawnm@wp.pl
shawnm<P>miata 1,6 <BR>UIN 21934953<BR>shawnm@wp.pl
Re: Advanced timing
If you advance the timing, the ECU will retard it back.<P>------------------<BR>David Coleman- <B><I>Moderator</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><I>Why get clear tail lights when only Geo Metros are gonna see them?</I></B>
David Coleman
Re: Advanced timing
hey dave wouldnt he be able to un plug the advance like you would on most fords? you know the lil plug off the distributor<P>------------------<BR>92 MX-3 GS<BR>brillant biege<BR> spawn_46375@yahoo.com
92 MX-3 GS<BR>brillant biege<BR>www.angelfire.com/in3/spawn46375<BR> spawn_46375@yahoo.com
Re: Advanced timing
It is ECU controlled. If you unplug it, it wont work too well. Trust me on this one
David Coleman
Re: Advanced timing
I did advance timing, but even my mechanic told me the Ecu will control it. <BR>Is there any other way to fool it>?<BR>I might change for Superchip, maybe it will help<P>------------------<BR>shawnm<BR>MX-3 red blaze...POLAND<BR>UIN 21934953<BR>shawnm@wp.pl
Re: Advanced timing
I have tested the distributor advance on a dyno and gained no power at all<P>its all controlled by the EPROM tables<P>you need to do it from the EPROM<P>Steve<P>------------------<BR>All motor 176WHP Mx3 - Dyno test coming in April
Re: Advanced timing
Steve do you reprogram the ECU ??<BR>or where? how much?<P>------------------<BR>Clear White 2.5L GSR
Re: Advanced timing
I can get EPROMS that are already re programmed for more advance timing for the 94 2.5 Liter ECM.<P>Its 100 dollars and you need to have it installed.<BR>You could do it if you are good with the soldering iron or pay some electronic store to do it.<P>Steve<BR><P>------------------<BR>All motor 176WHP Mx3 - Dyno test coming in April
Re: Advanced timing
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by cybertekguy:<BR><B>I have tested the distributor advance on a dyno and gained no power at all<P>its all controlled by the EPROM tables<P>you need to do it from the EPROM<P>Steve<P></B><HR></BLOCKQUOTE><P>Or, of course, you can install the S-ITC from Apex like I did and control the timing that way.<P><P>------------------<BR><B>Jeff Abrams</B><BR> jeff@mazdamaniac.com <P><B>SUPERCHARGED</B> 2.5 liter 1993 Mazda MX-3 GS <BR> <A HREF="http://www.mazdamaniac.com" TARGET=_blank>http://www.mazdamaniac.com</A> <BR>Normally aspirated 1997 Mazda MX-5 Miata
Re: Advanced timing
What are the cost and gain comparing to each other :<BR>1. New chip ( Superchips) gain i heard 0,5 s<BR> ( in Poland chip costs 300 USD )<BR>2. Apex S-ITC gain????? it controls only advanced timing or sth else too?<BR> ( in Poland its not available)<P>i have 1.8 v6 liter ( with KN filter, spark plugs, and exhaust)<P>thx<P>------------------<BR>shawnm<BR>MX-3 red blaze...POLAND<BR>UIN 21934953<BR>shawnm@wp.pl
