Having problems with my amp.
MazdaManiac93
My amplifier is making noises. When I turn up the bass on the amp, the subs start to pop in an out really fast and making noise at the same time. What can I do to stop this.
- monty73741
Re: Having problems with my amp.
also make sure ur rca's are on the opposite side if the car
Jason Danaher
Please Help Support MX-3.com
MazdaManiac93
But I hooked up the same amplifier in a friend of mine's car and the promlem still persists. What is this???
try turning down the gains on your amp or the bass boost on your head unit. sounds like you might be clipping your amp.
seneca
hey what kind of amp, and how old is it? It could as menyioned above..just be your levels. Just turn everything down and start from there! I fnot it could be your subs?....have you tried a different amp in your car yet?
keep us updated
keep us updated
My Car Domain Page:
http://www.cardomain.com/memberpage/496099
Take a Look, leave a comment, and don't forget to vote.
Tyler17rose
If your amp is clipping its probably either wired up at a lower ohm level then its made for or, its got a bad ground. Try grounding it to bare metal. Sand off the paint and tighten the ground down onto the frame. If its still clipping make sure you have your sub/s wires at 4ohms and you should be safe since almost all amps are 4 ohms stable. Goodluck
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
It's probably a loose connection within the amp. If it still does the same thing in a different car then the problem has to lie within the amp.
I'm SomeGuy from http://someforum.net
MazdaManiac93
Thanks. I will try that.
