So supposedly the newer casts KLZE's are lower compersion.
Is there actually any proof that these 9.5:1 pistons exist? I've never seen any pics of them.
9.5:1 Pistons do they exist?
Re: 9.5:1 Pistons do they exist?
Does anyone know what there suppose to look like?
I've got a newer casting KL, looked in the combustion chamber. There not DE Pistons, but I dunno how to see the difference between the supposed 9.5:1 and 10:1.
These are the best pics i have:
edit: this is supposed to be a KLG4 9.5:1 piston:
So heres a question...is the ZE higher rated HP due to the higher compression only...if its not and from my understanding is basically a DE anyways can you just use the lower compression pistons from the DE if you want to run boost?
Well no, cause the cams, intake, ecu also matter.
And a DE is 9.2:1 Compression.
KLG4 is a 170hp engine and is basically a DE.
But what is an an J-Spec engine like this called, its not a DE but neither a ZE.
Supposed to be:
9.5:1 pistons (or 10:1 ???)
Redesigned DE heads
KL-01 Cams
Redesigned oil pan
Only seen one dynod, made 190bhp. But still piston's unconfirmed.
I don't see it:
Also top and bottom are mirror imaged, where as the 10:1 pistons are not. My conclusion is this engine has 10:1.
Supposed to be:
Redesigned DE heads
KL-01 Cams
Redesigned oil pan
I don't see it:
- MrMazda92
Millenia KL + Japanese ECU/VAF combo = ~185-190 BHP
KL31 cams, KL31 heads, and the higher static CR make up a whopping 10-15 BHP combined. I would invest that money elsewhere, were I planning to buy a new engine.
