Need help identifying a vaccum during swap
pattheriault
Post by pattheriault »
Hose that goes behind the intake manifold just beside the vris actuator.(I have a curve neck). is this supposed to be plugged under the throttle body?
here's a close up of the vaccum
mx3_ryder
Re: Need help identifying a vaccum during swap
Post by mx3_ryder »
Yes cap it off... :)
pattheriault
I know I need to plug it! but where ? or basicaly what I need to know is under the TB theres 2 plugs on the IAC.. are both of these for a vaccum hose?
mx3_ryder
Post by mx3_ryder »
Sorry, dont' cap it off I was thinking it was another vacuum port below. I actually have my brake booster hooked up on that port beside the VRIS and have my pcv valve hose hooked up where your brake booster is plugged in. The 2 plugs under the TB are for the coolant lines. Did you take the old engine out?
pattheriault
yes I did but it was over a year ago.. that why im a bit confused
mx3_ryder
Post by mx3_ryder »
Take a close up picture of the front of your engine for me.
pattheriault
by front do you mean left side? or the timing belt side?
mx3_ryder
Post by mx3_ryder »
Picture of entire engine standing in front of radiator.
pattheriault
There's a open nipple just beside the one that is plugged to the brake booster but pointing backward instead of upward like the one for the brake booster.
mx3_ryder
Post by mx3_ryder »
This image is from a mazda millenia and you can see where the brake booster hose and pcv hose are routed.
pattheriault
just found my old manifold and the nipple I was asking about was plug so i think im all good. that pic make me doubt my pcv routing but ill see on start up.
mx3_ryder
Post by mx3_ryder »
Great, did you figure out the coolant lines for the TB?
pattheriault
yes every thing seem to be figured out! I still have a few ground to plug. just finished puting back my exhaust in place! Im only waiting on my new spark plug wire to come in tomorrow morning to fired it up
pattheriault
where do you guys placed the ground beside the starter?
One ground from engine to passenger side engine mount, one clips onto the trans at the top and goes to the frame i believe. Never hurts to add more grounds. There is a big, like 3/4" wide 90deg vacuum hose that's about 2" long right below your VRIS. You would need to disconnect it to take the intake off. Make sure it's connected cuz it's big azz.
