boging, hesistation
mx3matt
boging, hesistation
Post by mx3matt »
i'm not even sure what to call it really. but 90% of the time when i'm driving i get a weird bog/hesitation that i think may have to do with the vris, but when i rev it up in the driveway visually everything seems fine and vris shutter open smoothly.
i find that in 1st,2nd and 3rd if i'm cruising along at about half throttle and floor it i get a very quick brief hesistion/bog and then what feels like boost when it does kick back in, i've driven 2 other k8's for comparison and they dont do it.
It feels like theres a quick load on the motor that bogs it for maybe half-1 second at the most and then hauls hard again.
it was doing this since the day i bought the car but has gotten worse over the last few months.
MrMazda92
Re: boging, hesistation
Post by MrMazda92 »
I'd say throttle position sensor, as opposed to VRIS. Most people wouldn't notice the difference in VRIS points being off, but anybody would feel a difference with a mal-adjusted TPS.
There's a writeup in the V6 FAQ on setting it, It's well made and will set you straight if that's your issue! :2thumbsup:
mx3_ryder
Post by mx3_ryder »
I WOULD SAY CHECK TPS AS WELL BUT ALSO CHECK FUEL FILTER, I HAD A SIMILAR PROBLEM AND MY DISTRIBUTOR AND POINTS ON THE CAP WERE CORRODED, CLEANED THEM UP AND PROBLEM SOLVED. GUESS IT WAS RANDOMLY ARCHING INSIDE THE CAP.
