Miata Pistons will fit ?
Hi,
i'm are rebuilding my MX3 1.6 DOHC B6DE engine, and i wanna know if the Miata 1.8 pistons will fit...
http://cgi.ebay.com/ebaymotors/01-05-1- ... 1922wt_939
I'm are from MX3Zone Brazil, and it's a big doubt here about that.
Thanks
Thanks
- DeadMaker
Re: Miata Pistons will fit ?
No..Different bore size.
Last edited by DeadMaker on September 12th, 2011, 2:03 pm, edited 1 time in total.
Black Mazda Mx3 Rs 1997 B6DE
there are many 1.6L pistons that will fit.
http://www.importperformanceparts.net/
go to Mazda->Pistons and choose a manufacturer. There are also many aftermarket rebuild kits on that site for the all the B series engines. go to Mazda->Engine Kits->Topline OEM Engine Kits. The B6 and B6ZE are both listed. I believe the B6 they are referring to is the SOHC and the B6ZE is the DOHC.
Thanks...
I will get the B6ZE pistons with .50 oversize... Anyone knows if i can get bigger ?
And i will put the B6ZE valves with 1mm oversize... For better peformance
- Josh
bmagera91 wrote:Thanks...
There is a lot of information available to you on this forum you just have to use the search tool above.
I don't know if I would go much bigger, depends on what you are doing with it (Goals), Keep in mind that this motor started its life as a 1.3L and was bored to a 1.6L I know you can bring it to a 1.7L without stroking it, but its really only recommended if you are running it N/A.
- Josh
The B6 is a overbored 1.3L from the factory.
- DeadMaker
You mean the soch version,cause this guy has doch.
All the B series engines except the BP are made from the same basic block casting. There are a few different ports for oil and coolant but they're all basically the same. SOHC or DOHC is determined by the head, not the block.
- Josh
Hit the nail right on the head.wytbishop wrote:All the B series engines except the BP are made from the same basic block casting. There are a few different ports for oil and coolant but they're all basically the same. SOHC or DOHC is determined by the head, not the block.
Deadmaker: What I was saying is that the 1.6L (whether it be a SOHC or DOHC) was originally designed to be a 1.3L. The 1.5L and 1.6L are bored out variants of the original 1.3L motor. All share the same block, the heads CAN be interchanged some with complications, but for the most part are the same otherwise. The OP was mentioning he wanted to know how far he could bore the motor, well the 1.6L being bored over already, does not leave much room.
- DeadMaker
Thanks for the information I didn't have an idea that it was bored version...Wikipedia also reffers to that.
If it's bored doesn't this mean that it looses some strength in block from the unbored version?
Wiki also says that bp featured a forged crankshaft!
Another reason to upgrade a bp and not a b6..
How much you think a bp can be bored?
Standard overbore pistons are usually available in .050", 0.100" and 0.150" increments. Some manufactures offer .5mm, 1mm and 1.5mm overbore pistons.
0.150" over would get you to just over 2L. 2012cc to be exact. I wouldn't go over that.
