KLDE Swap Question
KLDE Swap Question
Hey guys been a long time. I miss my MX3 so much. I'm here in Vegas and can't find one V6 with the 5 Speed. My question is can the 5 speed from the 4 banger mate up to the KL or now? Also will the KL have any problems dropping into the 4 banger engine bay? All I can find here are 4 bangers with 5 Speeds or automatic V6s how hard would it be to put the 5 speed from another car into the Automatic? Ultimately ima have the 5 speed with a KLDE. Any and all input appriciated.
Re: KLDE Swap Question
I can say from personal experience it is alot of work to put the KL-DE in a 4 cyl MX-3. I am just completing this swap and it took much longer than I expected. I used the motor and 5 speed tranny from a probe gt and the engine wiring harness from a MX-3 gs. I still have a few bugs to work out but yes it is possible and it fits like a glove.
If your goal is KL w/ 5 spd then get a v6 and plan on transplanting both the engine and transmission. Expect some additional work and parts to do the manual conversion (linkage, pedal, clutch master and possibly axles). Do your homework with the earlier referenced link and you should be prepared. You might also continue the search and start with a v6 5 speed. They are around you just may have to wait to find one locally for the price you're willing to pay. Good luck.
Of course it does, the car is designed for it. The problem was never fitament, its the amount of stuff that needs to be replaced, basically a 4cyl-to-v6 converstion in the engine bay.tbondo wrote:it fits like a glove.
There's a whole thread with the shopping list on what parts you need for a 4cyl to v6 swap, but I can't seem to find it, but it's a big list. Ideally you would need a doner GS to have all the parts on hand.
