Klze swap
mitchell_jarvis
Klze swap
Post by mitchell_jarvis »
i have a few questions about a klze j-spec swap.
1) would the transmission off my 18L v6 fit on the Klze?
2) do i need to change my eco from an OBD-II to a OBD-I?
3) and would i need a different wiring harnes that the one i have?
4) last, are the motor mounts the same?
_-Night-Shade-_
Re: Klze swap
Post by _-Night-Shade-_ »
1)yes
2)no
3)no
4)yes
If you have any more questions you can find the answers to them by using the search function.
Pritchett
Re: Klze swap
Post by Pritchett »
1. Yes
2. Not sure
3. Nope
4. Yes
I haven't done the swap myself yet. I'm a new member but I've visited many times as a spectator. I've read many peoples swaps..night_shades WL being the most recent. So feel free to correct me if I'm wrong on anything I said.
edit- took me 4 minutes to write that....
93 mx-3 GS (KLZE w/kl01 cams, XTD stage 3 clutch, Outlaw intake/throttle body spacers, throttle body coolant delete, headers, full 2.5" exhaust w/resonator and 40 series flowmaster, filled engine mounts)
99 silverado
SpatialTerror
Re: Klze swap
Post by SpatialTerror »
other than the intake manifold the k8 and the kl look identical. its just like swapping the same motor pretty much
SpatialTerror
_-Night-Shade-_
Re: Klze swap
Let me correct myself about #2 - if it's manual then yes.
slayer322
Re: Klze swap
Post by slayer322 »
^ what they said, pretty much everything is plug and play, exhaust work will be needed since the headers will be different
1996 Mazda MX-3 GS - DD / Always a project Car
ZE + Pacesetters = <3
