92 Mx-3 1.6L wont start
Hey guys, was driving my 92 all pefectly, Stalled on me in the road i pushed it off to the side. Cranks cranks cranks with no sign of turning over, checked the code it showed #2, Which i think is the distributor? Would it just die on me like that and not restart? Before this car has been very very reliable and never left me stuck like this
- Ryan
Re: 92 Mx-3 1.6L wont start
In the FAQ, http://www.mx-3.com/phpBB3/viewtopic.php?f=24&t=65390" onclick="window.open(this.href);return false;
Code 2 is NE signal, which is indeed inside the distributor.
Thats an odd failure on '92 RS's
What exactly is the NE signal mean? In the meantime should i buy a new dizzy? I am semi-new to mazda's owned this car about a year and distributor on there looks pretty original
- Ryan
The NE signal is the signal that the ECM uses to space the sparks. It should give 6 5 volt pulses for each revolution of the camshaft. It is a hall effect sensor located in the disty.
- umcamara
Just to recap...trife86 wrote:Hey guys, was driving my 92 all pefectly, Stalled on me in the road i pushed it off to the side. Cranks cranks cranks with no sign of turning over, checked the code it showed #2, Which i think is the distributor? Would it just die on me like that and not restart? Before this car has been very very reliable and never left me stuck like this
Cranks == turns over
Runs == fires up = starts
turns over DOES NOT == starts
As you were...
One other silly questiong, Looking on rockauto to buy a new one. They have listed ones with different diameter rotor cams? Does it matter which one i get? I would like to get the cheapest one they sell which rockauto for that one does not list differant sizes?
BTW well engine turns over perfectly but does not fire up
Well changed the dizzy out today, Easy swap out and all good, Didnt retime it just kinda marked where old one was all good!
