SS Frame guards
SS Frame guards
OK so I check under my car and see that over the years garages have distorted the areas of the frame they use to put the car up on a hoist. My plan is to fabricate stainless steel U shaped rails that I plan to epoxy over these 4 areas (two in front, two at the rear). I guess it's to be expected that over the years this is bound to happen. Now if I have to take the car to the garage I'll let them know to position the lift pads on these four stainless reinforcements. Pure genius if you ask me.
Re: SS Frame guards
Mine is really bad too and i'm starting to get a bit of rust in the seams so I'm planning on replacing the floor, frame rails and rocker panels during the rebuild. But I have been thinking about reinforcement there as well to prevent recurring problems.
Good idea in my opinion.
- _-Night-Shade-_
Re: SS Frame guards
Great idea! I think this is a common problem on a lot of MX-3s, mine included. Let us know how you plan on doing it.
- fowljesse
Re: SS Frame guards
Sheer, utter, and pure genius!
Now, if you got the Stainless from Martini shakers, or something like that...
Re: SS Frame guards
OK so far the cost of fabrication is killing me. Two large Tim Horton coffees avec 2X cream. lol We're doing them in 1/8 stainless and after examining the under carraige of the car I had to modify the original design and there will be holes to drill and some additional bending of the stainless. If I get them exact enough I'd like to see how much it would be to produce more (GB). I'm thinking the cost of SS is a little prohibitive for most but we do have a scap metal dealer here who may have some in his bin. The frame will need to be cleaned and neutralized then I plan on using epoxy blended with micro balloons to attach them. The epoxy is more for void filling and holding the mounts in place than anything structual. More to follow.
- Tollis
Re: SS Frame guards
Thats a Genious idea. I've recently replacedsome of the frame rails I might do what your doing to cover up my work. Don't want them to question anything when I bring it in for safety :p lol
Cody
1993 GSZE SE
1993 GSZE SE
Re: SS Frame guards
I'll probably get the car in the air in a couple of weeks. I'll need to custom fit the guards then if it looks good I'll see if getting a few more made is possible and I'll include a drawing with all the specs. The rear rails are a little more complicated so I'll see how I do. not usre about you guys but I have a hard time finding time to get anything done. Still have to tile my bathroom then build a new kitchen and refloor it. I should of been born twins.
- fowljesse
Re: SS Frame guards
Daninski wrote: I should of been born twins.
There are almost too many of you already.
Could you imagine the fights you'd have?
Now, if one of you had a goatee, and was the good one...
That might be okay.
Re: SS Frame guards
if this did turn into a group buy I'd be interested. My car's underbody is definitely in need of a good cleaning. Got a decent bit of Rust (not too severe though), and really need to get at knocking it all out.
