This might be a stupid question but the flasher unit here:
viewtopic.php?f=38&t=39052" onclick="window.open(this.href);return false;
how do u remove it? i dont want to snap nething off but i cant really see how to get this bad boy off... any hints?
How do you remove relay?
Re: How do you remove relay?
you can pretty much see from that picture, there ain much to it. you just pull it straight down off the bracket. there is a notch on the housing that clicks into a corresponding cutout on the bracket, so you'd want to take a flathead and kinda jam it in there to release it.
thanks i wasnt sure if it was attached somehow on the top lol i'll try this tmr
actually did u mean the whole white sleeve comes off... or does the black part slide out of the sleeve?
the whole thing comes out. if you look at that picture in the link, the metal tab right there at 1 o clock on the red circle, that's exactly what is holding the relay on. you can even see the lil cutout
yea i just yanked.. worked like a charm thanks! replaced with some led bulbs so now they blink normally ![Very Happy :D](./images/smilies/icon_biggrin.gif)
