pheno spacers
pheno spacers
just a quick question i bought a set of spacers, but i have a de and there for a ze/// will this cause restriction at all when using the gaskets ?
						- WhiteFinish
Re: pheno spacers
Quick answer : yes
						- mitmaks
Re: pheno spacers
just port match them
							Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE  '95 Cobra SVT #2722 '68 Charger R/T 440
Re: pheno spacers
He would be using ZE spacers on a DE, so no there would be no restriction since the square runners are larger than the rounded ones. You could port match the heads, but the IM would still be the round runners. The only thing with those spacers is that they probably block the EGR hole on the IM.
- fowljesse
Re: pheno spacers
They would just cause minor tubulance, which may help the "swirl" when the gas and air mix. I would check to see if the DE oval ports are wider than the sqare ZE spacers, but I think they're the same.
						- muttpower
Re: pheno spacers
Just use your ze spacers as a stencil, and port your intake runners to match them...takes less than 1 hour....
							1992 MX3 GS (My Project Toy)
K8DE, see web site...too many mods to list, but still growing.
2006 Dodge Durango (The Family-Mobile)
Every time you race a Honda Civic, a kitten kills a retard.
