Adjustable Fuel Pressure Regulator Install
hey guys i need some help installing the adjustable fuel pressure regulator how my ZE can someone help thanks
Re: Adjustable Fuel Pressure Regulator Install
there is a gas line that comes from under the IM on the right side..and it goes to your fuel rail ( stock fpr) remove the line ( after letting out the pressure) unbolt the stock fpr put on ur new adapter..with an oring.. then hook that line u unhooked into your "in" side on the afpr then put a line from the "out" side to the adapter... clamp them.. and start the car..and adjust the pressure to 45 i have been told and have read... ( put the vac line on too ) from the stock one to the only spot on the AFPR ... ta daa... search google..there all the same just different areas on diff cars..
k kool give her a shot thanku
where can i get the adapter to replace my stock fuel pressure regulator ?
- RS_OBD'oh_2
it can be found in the search section
Or you can simply disconnect the vac line and connect your AFPR before it.
i dont understand sorry
leave your stock FRP in place..and block that vaccume hole.. and jsut hook up the vac to the AFPR and install same way.. your kit didnt come with one ?
it didnt come with the adapter, will it still work if i leave the stock pressure regulator on i thought the gas has to go through the fuel rails
it does ? .... just run the line to your in from the back of the IM then run a line from the OUT to the stock fpr... it goes into the fuel rail ?
ohh kkk kool thanku
