[WTB] Power Window Drivers Switch
- Jovian2k
The passenger switch just broke off. I need the whole handle... let me know!
- 2fazed
Re: [WTB] Power Window Drivers Switch
which side do you need? title says drivers side, description says passenger.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
I'm guessing he needs the complete driver's side assembly... It's difficult (maybe impossible - I tried) to replace just the passenger switch from the main module...
I see a few on ebay today....
- Jovian2k
yeah I need the drivers side switch (the passenger window switch from the drivers control broke). I may go the eBay route, figured I would check here and see if anyone had any to get rid of 1st!
christopher728
I've got a bad drivers side unit (doesn't work) if all you need is the plastic switch off of it. Don't know if that's what you meant by "broke", but if it is and you want to cover the shipping I'll just send it to you.
- Jovian2k
Like Mooneggs said... probably too hard to replace the broken switch so I will just swap the handle, thanks though!
I have one working great off a SE!
pm me
pm me
Jovian2k wrote:yeah I need the drivers side switch (the passenger window switch from the drivers control broke). I may go the eBay route, figured I would check here and see if anyone had any to get rid of 1st!
mine's the exact same way!
so if anyone has a second spare
Never be afraid to try...amateurs built the ark, professionals built the titanic.
- punkindrublic
i have one
im in hamilton Ontario...
could use a cleaning but works great !!!
1995 MX-3 GS (black) stock engine... for now hehe...
MSfront... mssides... GS wing...
5" tach w/shift light... A/F, Volt, & Oil Pressure gauges in dash vents... front and rear strut braces....
WORK IN PROGRESS
WORK IN PROGRESS
