Smell of gas and oil
i notice sometimes while driving my 1992 mazda mx-3 GS 5spd that my car does stink. The reason why this is bothering me is because i have to go through Delaware state inspection for the car within 2 months. They stick a emissions sniffer up the tailpipe and let you know if your car is compliant. By getting out of the car and smelling near the back, it smells as if there is oil and gas burning. The car has a aftermarket muffler but that is it. I replaced the 02 sensors and the car has no check engine codes when i recently scanned it. Oh and when i had the car on a lift the catalytic converter was still there. Please let me know if anyone has run into a similar problem. Thanks.
- mx3autozam
thanks for the responses. Whats funny is, this morning when i was warming the mx-3 up i stepped out and noticed that not only was exhaust coming out of the rear muffler but halfway underneath the car it was also coming out. Back behind the catalytic converter but before the muffler. Where the tubing snakes around . So im wondering if this exhaust leak could be causing the car to smell so bad. It goes through cat but isnt going through muffler all the way apparently. And by the way, the pipes have some rust on them and looks like it may be eating through some areas. If you think this will fix my problem then i will replace the exhaust pipes. Has anyone ever done this>? and round abouts how much did it cost? imma do some research tomorrow.
- tehbrookzorz
