I need to replace the back heads intake gasket.......
is this just a stock part for any k-series? even with the curve neck intake mani??
thanks for any help
klze intake gasket
MX34M3
- BANNED Member
klze intake gasket
Banned for not following rules.
- papa roached
just as long as you get a millenia one, the intake gasket needs to have the same shaped holes as the runners on ytour intake
- mx3autozam
- papa roached
yea as long as yours are KL31 square port heads they should, if they arent square you dont have a klzeMX34M3 wrote:but will they match to the head?
