Is there a guide somewhere on how to set these things?
Or at least a pinout so I can manually open and close it while I'm cleaning
Idle Air Control Valve (SOHC B6)
What doesn't kill me, postpones the inevitable.
I don't know what you mean by "set." The iac valve has no settings and operates automatically. I would like to remove mine for cleaning, if it can be cleaned, but I can't figure how to take it off. I see one screw and nothing else holding it on, if I am looking at the right part (black plastic part under the throttle body). When I remove that screw, the part does not want to come off. Don't want to pull too hard for fear of breaking it.
David Lochabay
Saipan, Northern Mariana Islands
Black 1993 MX3, MT, 1.6 SOHC
