Addendum to last exhaust dilema.....
mx3gtracer
Post by mx3gtracer »
Ok I had previously mentioned buying a hi flow cat or a straight pipe, did so, got it, looked under the car today to see exactly where it would fit....not happy. I didn't even realize I had such a huge resonator in there and didn't quite see the cat but I couldn't see very well. So, now I'm looking for an affordable cat back exhaust for a 95 1.6L DOHC 4 cyl, something direct bolt on and I'm considering matching this up with the header on corksport. I BSed on previous cars but I'd really like to do this car right.
It's kind of important that this thing bolt on directly as welders kinda cost a lot in this area.
WingleBeast
Post by WingleBeast »
there is really only one in production and that is the pacesetter. you can get it for about 180 new on ebay. the only other one is still in testing by corksport and no news on when it will be released. other than that you have ot go custom
mx3gtracer
From what I've seen the pace setter cat backs are all for the 92 to 93 model.... who's testing the one for the 95 1.6L?
mx3gtracer
oops should've read a little better lol
ariesdude
Post by ariesdude »
I dont know if you are looking for this kind of catback - i'll just throw it out -
http://www.rockauto.com/catalog/x,carco ... ttype,5880
http://www.rockauto.com/catalog/x,carco ... ttype,5872
But if you go custom with a good exhaust shop it might be cheaper.
94 Mx-3 Precidia
95 rs
Post by 95 rs »
vibrant by toucan also has one for the 1.6l dohc..... if your in canada you can get it through canadian tire as it will only cost about $330
WingleBeast
the toucan one isnt a real cat-back, its an axle back, just the rear section
mazdamx3sohc
Post by mazdamx3sohc »
i found the toucan one ;-)
