Ok I had previously mentioned buying a hi flow cat or a straight pipe, did so, got it, looked under the car today to see exactly where it would fit....not happy. I didn't even realize I had such a huge resonator in there and didn't quite see the cat but I couldn't see very well. So, now I'm looking for an affordable cat back exhaust for a 95 1.6L DOHC 4 cyl, something direct bolt on and I'm considering matching this up with the header on corksport. I BSed on previous cars but I'd really like to do this car right.
It's kind of important that this thing bolt on directly as welders kinda cost a lot in this area.
Addendum to last exhaust dilema.....
I dont know if you are looking for this kind of catback - i'll just throw it out -
http://www.rockauto.com/catalog/x,carco ... ttype,5880
http://www.rockauto.com/catalog/x,carco ... ttype,5872
But if you go custom with a good exhaust shop it might be cheaper.
94 Mx-3 Precidia
vibrant by toucan also has one for the 1.6l dohc..... if your in canada you can get it through canadian tire as it will only cost about $330
95 rs with custom short ram air, b&m short throw shifter, probe 2.0L header with 2 1/4" exhaust all the way back, catco high flow cat, apc high flow muffler with 4.5" tip, accel 8 mm wires, blaze red, cf altezzas, gun metal 17" mr7s, slotted cross drilled rotors on the way with hawk hps pads, red and white interior, other then that its stock.
