Trying to change the clutch in my car right now and the bolt that holds the shift rod to the transmittion wont come out...
Any ideas?!?!?
Bochek
Help Please! urgent SHIFT ROD BOLT
- JWMX3
you didnt have to do that.... if you strech back the rubber boot where the shift rob bolts to tranny there is a 10mm bolt that will get it off for you, actually when i recently had my motor out i didnt even bother withthe shift rod bolt, i just went straight under the boot.... why struggle when you dont have to ?Bochek wrote:
I ended taking off the other end of the shift rod and taking out the whold shift rod with the transmittion.
Thanks for your help,
Bochek
you can still do that now, so you wont have to try and put the trans in with a dangling shift rod
