Sup fellas.
Here's the question.
My buddy has a KLZE swap in his 93 mx-3.
Well the whole automatic transmission thing didn't work out so
were gonna do a manual conversion.
Do I need to use a 2.5 v6 transmission/shift linkages etc. out of a probe or out of an mx-6, or is it better to use the manual 1.8 v6 tranny
out of the mx-3?
Reason being, I know where a wrecked M/T mx-3 is but I don't want
to get it if the tranny won't work with the KLZE.
Thx, Chris
v6 manual conversion question.
- PATDIESEL
Make sure to rob the master cylinder, brake booster, pedals, shift knob, actual shift lever, shift boot, slave cylinder hard line and rubber line (or get a stainless steel one from CorkSport) and the aforementioned shift linkage from the MX-3 GS at the junk yard.
- PATDIESEL
I'm not sure of the differences, but they are not the same part number if memory serves me correctly. I also didn't know the atx just had a cap over the clutch line.
I guess make sure to check your MX for the cap and if it has one then you are in the clear about getting all the engine bay brake stuff. It will save a TON of time. The last MXT swap we did, the brake booster and stuff was about 1/3 of the time it took.
Great to know that they do have the slave cylinder port in the ATX MC. Thanks guys [even if about a year late]
i think i only took about 8-10 hours to do the whole job on a mx6. i sent for time going to the junk yard to get the parts i misted the first time lol
it's on the probe are now, but it's moving to the mx3 soon.
m62 suercharger, megasqurit, headers,custom exh. 9lb. flywheel, stage3 clutch, & so much more.
http://www.cardomain.com/ride/1301296/1
