v6 manual conversion question.
skdrcr
Post by skdrcr »
Sup fellas.
Here's the question.
My buddy has a KLZE swap in his 93 mx-3.
Well the whole automatic transmission thing didn't work out so
were gonna do a manual conversion.
Do I need to use a 2.5 v6 transmission/shift linkages etc. out of a probe or out of an mx-6, or is it better to use the manual 1.8 v6 tranny
out of the mx-3?
Reason being, I know where a wrecked M/T mx-3 is but I don't want
to get it if the tranny won't work with the KLZE.
Thx, Chris
JWMX3
Post by JWMX3 »
you need the linkage from an mx3
the tranny itself can come from any of the cars mentioned...probe,mx6,626,mx3
Custommx3
Site Administrator
Post by Custommx3 »
the PGT and MX-3 trannies are identical, the mx-6 has a longer 5th gear.
PATDIESEL
Post by PATDIESEL »
Make sure to rob the master cylinder, brake booster, pedals, shift knob, actual shift lever, shift boot, slave cylinder hard line and rubber line (or get a stainless steel one from CorkSport) and the aforementioned shift linkage from the MX-3 GS at the junk yard.
deathman
Post by deathman »
why would you need the master cylinder, brake booster? i converted a mx6 with no problem with out the master cylinder, brake booster, but i know you need all the rest
JWMX3
Post by JWMX3 »
you dont need the brake master cyl or brake booster... the reservoir on my original one just had a cap over where you plug the clutch line into
deathman
Post by deathman »
so the master cylinder supples the clutch master cylinder it's brake fluid.
PATDIESEL
Post by PATDIESEL »
I'm not sure of the differences, but they are not the same part number if memory serves me correctly. I also didn't know the atx just had a cap over the clutch line. :roll:
I guess make sure to check your MX for the cap and if it has one then you are in the clear about getting all the engine bay brake stuff. It will save a TON of time. The last MXT swap we did, the brake booster and stuff was about 1/3 of the time it took.
Great to know that they do have the slave cylinder port in the ATX MC. Thanks guys [even if about a year late]
deathman
Post by deathman »
i think i only took about 8-10 hours to do the whole job on a mx6. i sent for time going to the junk yard to get the parts i misted the first time lol
it's on the probe are now, but it's moving to the mx3 soon.
m62 suercharger, megasqurit, headers,custom exh. 9lb. flywheel, stage3 clutch, & so much more.
http://www.cardomain.com/ride/1301296/1
