why does my engine feels like it has hiccups?
mx3_rider69
Post by mx3_rider69 »
everytime when my car comes to a stop it feels like the engine kicks and the rpm drops sudenly up and down when the engine kcks and when i press on the gas it hesitates to go first but then its ok any suggestions
sorry not 2 technical!!!
neutral
Post by neutral »
One possible cause to rule out- Check the ribbed air intake hose closely for cracks which can allow unmetered air into the intake stream. Unmetered air can put the engine into a stall or near-stall. The crack(s) can be small enough that they only open to allow extra air in when the engine "flexes" a bit in its mounts - such as when stopping, or first accelerating from a stop. If cracks are present, a temporary tight wrap of duct ape will work to seal it til you can replace the hose.
Image -Jim
Does it only happen with your foot's on the brake pedal?
kp2t
Post by kp2t »
it is also a possibility that you have the wrong plugs in there.... If u put in ZFR on there, they are a longer spark plug....
mx3_rider69
i believe in does happen when i press the brake pedal
wat could it be
Zim_Zim
Post by Zim_Zim »
mine was doing the same thing and then i noticed a huge crack in my air hose so i duct taped it, been fine since no more hiccups.
midrange
Post by midrange »
possibly a pinched vacuum line as well.. dirty injectors too could cause it..
93 MX-3 GS
DavidOS
Post by DavidOS »
hiccups point to alot of areas...
known cures are
1) plug the intake and make the car hold its breath as long as it can.
2) a glass of sugar water in the gas tank helps 2
3) try to scare her somehow, i find running on a tank of 89 octane is pretty scary!!
if you have any other remedies please share
nos92mx3
Post by nos92mx3 »
guys hes joking(i hope)
I wouldnt want a newbie to come accross this and go pouring some sugar water in his tank and then posting on here of how it didnt work. :P
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
Tunes67
Post by Tunes67 »
I found that hypnosis worked well to get rid of my cars hiccups.. the trick was finding a shiny coin big enough to swing back and forth in front of her head lamps so that she didnt get distracted while I was hypnotizing her. Had to use a engine hoist to hold the coin by its chain in front of her.. then me and a buddy pushed it back and forth till she went under.. only took about 5 minutes too. She hasnt hiccuped since ;)
Tunes67
Meep
Post by Meep »
You guys entertain me so...
:laugh:
