why does my engine feels like it has hiccups?
- mx3_rider69
everytime when my car comes to a stop it feels like the engine kicks and the rpm drops sudenly up and down when the engine kcks and when i press on the gas it hesitates to go first but then its ok any suggestions
sorry not 2 technical!!!
- neutral
One possible cause to rule out- Check the ribbed air intake hose closely for cracks which can allow unmetered air into the intake stream. Unmetered air can put the engine into a stall or near-stall. The crack(s) can be small enough that they only open to allow extra air in when the engine "flexes" a bit in its mounts - such as when stopping, or first accelerating from a stop. If cracks are present, a temporary tight wrap of duct ape will work to seal it til you can replace the hose.
-Jim
Does it only happen with your foot's on the brake pedal?
- mx3_rider69
hiccups point to alot of areas...
known cures are
1) plug the intake and make the car hold its breath as long as it can.
2) a glass of sugar water in the gas tank helps 2
3) try to scare her somehow, i find running on a tank of 89 octane is pretty scary!!
if you have any other remedies please share
known cures are
- Tunes67
I found that hypnosis worked well to get rid of my cars hiccups.. the trick was finding a shiny coin big enough to swing back and forth in front of her head lamps so that she didnt get distracted while I was hypnotizing her. Had to use a engine hoist to hold the coin by its chain in front of her.. then me and a buddy pushed it back and forth till she went under.. only took about 5 minutes too. She hasnt hiccuped since
Tunes67
Tunes67
