help on greddy e-manage!!
				bugzy's mazda
O.k i know i haven't posted a lot on this website in fear i would sound stupid in front of you guys, but desperate time comes for desperate measures.  My problem is that i did a bpt swap this winter.
  Everything was easy all this info i read on the swap worked great, so kudos to those guys who wrote it.  Ayways my problem begins when i don't have the 323 gtx ecu and a stand alone system was to expensive.  I decided to but greddy e-manage piggy back system, by the way the engine turned on and ran somewhat normal with the mx-3 ecu, but with some minor kinks but it ran none the less.  I installed the piggy back system now the car don't want to turn on.  First i thought i hooked to the wrong air flow meter, because the mx-3 has two wires that come the airflow sensor one of them is constant and the other one varies but at idle.  i connected the constant 12 volt wire that didn't work it all it did was spputred and died. i connected to the other one and know the car doesn't turn on. if any one has any experience with this system or an idea of what might be the problem. i gladly appreciate it and my car is 1993 mx-3 rs
							Ride fast and ride hard you only live once.
