THANKS
True, you can just swap teh coolant neck w/the 3rd coolant sensor if you need to. Thats the only difference I know of besides the disty which you can swap out w/ease.lakersfan1 wrote:Why? The only thing I can think would be an issue would be the distributor from the MX3 would need to be used and the coolant neck from the MX3 used. Other than that, 92-97 are all interchangable.2fazed wrote:Try and match the years of your K8 and DE. 92 to 93 and 94 up.
When I researched the swap, before I got my DE, I was told from a 93 K8 to 94 DE, that modification to the sensors/wires were needed. I had a 93 K8 to 93 DE, and all the wires, sensors were fine. Besides exchanging the Vaf, Ecu, I had to use alot of the K8 parts instead of the DE, but didn't need to buy anything extra.Gro Harlem wrote:True, you can just swap teh coolant neck w/the 3rd coolant sensor if you need to. Thats the only difference I know of besides the disty which you can swap out w/ease.lakersfan1 wrote:Why? The only thing I can think would be an issue would be the distributor from the MX3 would need to be used and the coolant neck from the MX3 used. Other than that, 92-97 are all interchangable.2fazed wrote:Try and match the years of your K8 and DE. 92 to 93 and 94 up.
