Need help, My friend is worried.
ok, hes got a problem.. he recently stored his car about... 2 months ago, just before he stored it.. he did an oil change to 5W30, now that the car has been sitting he does start it, but very rarely...
the other day, we were checking out out... and we noticed something bad, the top of the oil cap was white/milky, and the pcv valve was clogged with this crap.
so we start the car run it for a good half hour take it for a drive... it runs perfect, doesn't overheat nada, we do notice however, its constantly making white smoke.. I don't know wether it was cold, or not but my mx-3 doesn't smoke at all, not even white smoke.. its very faint white smoke (not much at all) and very thin, anyways we shut the car off... popped off the pcv valve.. no more white crap, we check the oil (looks clean/gold)
and we notice theres not as much of this crap on the oil cap,
so whats goin on! my friend thinks his head gasket is toast... but I don't know I had one go on my old cavalier and it ran like crap!! his car is runnin perfectly fine!
btw this is a 93 gs aswell... do you guys think the white milky stuff came from the car barely being started or what? is his engine toast?
stock 93 GS, 5 speed
ok now where totally confused.. since that day we ran the car for at least 2 hours... so we checked the oil today, and now all the white s--- is gone, the pcv valve is cleared.. where stuck, maybe its cus it was sitting to long?
everything looks clean now, and the white smoke.. well it WAS -8C so... haha where stuck help.
- XxantwawnxX
If he started the car while it was stored. but he did not let it run for a long time...like maybe 5 mins. and he kept doing this, i think the crank case would get dirty because it takes a certain amount of running time /and or speed to have the crankcase ventalation system work correctly(pvc) either that are sumhow ur head gasket went bad while it was stitting. Maybe someone was secretly driveing the car ?? : P
- XxantwawnxX
Does you pvc valve click when u shake? Or do u feel the valve move when u shake it. hmm maybe he just blew his head gasket before he stored it.
- mitmaks
did you check coolant level? is white smoke still present when u drive it?
- Pedro_mx3
that happens allot in the UK in winter, normally its condensation (water) mixing with the oil on the oil cap, if the head gasket had gone the oil would still be milky, my old citreon used to get it allot when it had been sitting for a while, there obviously isnt oil all the way up to the oil cap so cold damp air can get in IMHO.
oh and the white smoke is probably steam, is it cold where u are?
I'm not worried about the bullet with my name on, Im worried about the one that says 'To Whom it may Concern'....
Make a Donation, Keep Mx3.com Alive!!
1991 V6 K8 -- My baby, i miss her... On her way to car heaven... <3
![Werd :werd:](./images/smilies/werd.gif)
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
