mounting an undercar kit
Well, I got myself a free set of decent neons..and mounted the sides and the front one before I put on my kit and all. I was wondering where you all mounted your rear tube at. Seems that the 3 ft tubes made for the front and back wont fit too well on the back..the muffler gets in the way a bit too much. Just wondering what you all did for yours. I really dont want to have to get a custom tube made about 1.5 or 2 foot.
Project Holy Crap!!!
L10 ATX Trannny In!
Project Turbo!!!
Finally Found A 5 Speed MX-3 in decent shape! B6T On The way now!
"Is it a mini-Skyline or an uderstated Supra hunter..."
RB25DET getting dropped into the 240SX as you read! Pics and Dyno graph coming soon!!
L10 ATX Trannny In!
Project Turbo!!!
- exdream_mx3
Re: mounting an undercar kit
Can you hook me up with a free set of decent neons? ![Froggie Red :froggie_red:](./images/smilies/froggie_red.gif)
mines squeezed right up in the bumper, and its not comming out ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Heh..wanna send me a few pics of your setup Nd4SpdSe? Wouldnt mind seing all 4 tubes just to get a good look at what other people have up. Kinda hard to see where other people mounted them at really. Always just get the night time pic of them glowing...
L10 ATX Trannny In!
Project Turbo!!!
L10 ATX Trannny In!
Project Turbo!!!
just fitted a kit to my m8's 323....
it was a squeeze on the rear with that but eventually made it fit!
the side one's are the worst with no skirts.... as all you can see is bulb!
he drilled his seam by choice how have you done yours?
check my car domain
http://www.cardomain.com/ride/2144443
Actually on the side of my mx..theres a small flap on each side of the car. I mounted the tubes right behind that. You can still see the bulb a little bit, but not much. Way Im lookin at it, whenever I get around to putting on my skirts they're going to be covered up completely. Same goes for the front when I put the lip from a GS on it. I might have found a way to mount the rear one, but it's going to be a pain in the butt it looks like. Short of me finding a tube thats shorter. Worst part is, white neons are hard to find down here in south florida for some reason.
L10 ATX Trannny In!
Project Turbo!!!
L10 ATX Trannny In!
Project Turbo!!!
I just got an led kit that changes 7 different colors. Its bad *** . But ya until i get sideskirts you can see the bulbs. The back was a tight fit for me as well but i think i cut one of the mountings for the bumper just to slide it in there. I'll post some pics once i get my camera.
Mx-3's rule
before I had my kit the way I had mine mounted was one behind just below the opening in front bumper hides it perfect can't see tube lights up front bumper opening and ground of course.
Side you can hide for most part behind the little rail under your car. When you add skirts you not see them at all anymore. Or you can go get a piece of rubber same lenght as tube and put it between the tube and the rail. This will totally hide your tube at night however in day time you'll see a little black strip under your car not really noticeable to anyone else just yourself. If you do the rubber idea another good idea is to take someting silver and put it on inside close to the neon tube, this will refelct the light better making it brighter
Back you can mount your back tube above your exhuast behind back bumper. This will totally hide the tube and also shines light threw the opening above your liencse plate.
Don't forget mount transformers away from heat, and also try not to use solder and use the plastic wire protectors. I only adding this cause of the trouble I had with mine
