temp. sensor swap on klze
jordan69
Post by jordan69 »
i was wondering about the fan thermosensor that you have to swap over to the KLZE. i just need to know what size hole i need to drill to put the new sensor in and what size threads i need to tap into hole to screw in the sensor?
You know the world is going crazy when the best rapper is a White guy, the best golfer is a black guy, The Swiss hold the America's Cup, France is accusing the US of arrogance, and Germany doesn't want to go to war
kenped8
Re: temp. sensor swap on klze
Post by kenped8 »
Drill hole size is 10.5 mm and tap is M12x1.5. Remember too use alcohol when tapping and not not oil or grease as it is aluminium. Good luck! i`ve just done it.
Klze,CAI,Exedy clutch, HM Engine mounts, HM ss exhaust system,Cobra lowering springs, 18" wheels.
mdavis
Post by mdavis »
Make sure you collect the filings that drop...
GS-R SE
Fixin's
jordan69
Post by jordan69 »
k, awesome, thanks guys.
