temp. sensor swap on klze
i was wondering about the fan thermosensor that you have to swap over to the KLZE. i just need to know what size hole i need to drill to put the new sensor in and what size threads i need to tap into hole to screw in the sensor?
You know the world is going crazy when the best rapper is a White guy, the best golfer is a black guy, The Swiss hold the America's Cup, France is accusing the US of arrogance, and Germany doesn't want to go to war
Re: temp. sensor swap on klze
Drill hole size is 10.5 mm and tap is M12x1.5. Remember too use alcohol when tapping and not not oil or grease as it is aluminium. Good luck! i`ve just done it.
Klze,CAI,Exedy clutch, HM Engine mounts, HM ss exhaust system,Cobra lowering springs, 18" wheels.
k, awesome, thanks guys.
