i need swap help
i need swap help
1) i got my ms8 manfiold to put on ze block can i just use the ms8 fuel rails or do i use the ze?
2) Which distrubuter do i use ze or mx3(my mx3 is BRAND NEW)
3) i need a detailed vris diagram to reinstall my Intake maniofld on my mx3 i forgot what goes where.
Re: i need swap help
1) Either should work
2) MX3 Unless the ZE is internal
3) no clue
3) no clue
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
I also need some help. Gonna swap to the KL-DE engine.
Do I need the engine complete with all cables or can I use the cables from the K8 engine?
You should be able to use anything from your existing parts. Just get the KLDE long block inlcuding the intake manifold and throttle body, and you should be good to go.Originally posted by Macen:
eat **** macen don't jack my thread......now is talons info cool? or anone got sometin to add?
Thanks lakersfan1!
MMike: Sorry, but I don't like to post a new thread with almost the same topic. So I thought it was ok. But I will remember that.
<small>[ June 19, 2004, 08:55 PM: Message edited by: Macen ]</small>
Talon info isn't correct about the second point
1. You can use both fuel rails, no problem
2. Use you stock mx-3 distributor the klze WON'T work
3. I can sent you some pictures of the vris I have a few klze engines around here, so that won't be a problem.
Bastian
Bastian
17 inch bba racings rims, apex lowering springs, laser muffler, boost steering wheel, mazdaspeed seats, black altezza's, testpipe, oh and a polished klze with an upgraded clutch and a kl36 ecu.
@Macen use your stock wiring harnass and use a 2.5 ecu and vaf.
- babyblueMX3
1-both have the same injectors and fuel rails so either one is okOriginally posted by MMike:
2-as of today never saw somebody use the ze disty except for a msd set-up and that was in a probe ..so that means use your stock one
3-it's not really that complicated...it's start from a nipple where the actuators are mounted..then there's the check valve and vacuum chamber..then it splits in 2..on goes into the first actuator and the second one in the other actuator..then each actuator goes to it's solenoid
RIP 400whp ZE-T MX-3
