Have u guy change or replace High or low pressure fuel filter or distributor regularly?<p>Do we have to?
what cost will be that?
Keep ur car run good regularly
Re: Keep ur car run good regularly
its wise to change fuel filters at the manufactures recomendation.. the filter isnt excessivly exspensive to do but its not a cheap filter either given mine has a bent neck..
-torp.
I don't own a Mazda.
- johnnyb
the filter will run you about $20 CAD as for installation im not sure how much a shop would charge because i changed mine myself. had to remove the battery and the plate the battery sits on to access it
![Image](http://i49.photobucket.com/albums/f292/amun931/mx3.jpg)
