Keep ur car run good regularly
greatunicon
Post by greatunicon »
Have u guy change or replace High or low pressure fuel filter or distributor regularly?<p>Do we have to?
what cost will be that?
a
torpedan
Re: Keep ur car run good regularly
Post by torpedan »
its wise to change fuel filters at the manufactures recomendation.. the filter isnt excessivly exspensive to do but its not a cheap filter either given mine has a bent neck..
-torp.
I don't own a Mazda.
johnnyb
Post by johnnyb »
the filter will run you about $20 CAD as for installation im not sure how much a shop would charge because i changed mine myself. had to remove the battery and the plate the battery sits on to access it
