Engine is revving?
Engine is revving?
My engine has begun to act funny. It seems to be revving on its own, and when the clutch is disengaged, it revs between 2.5 and 3 rpms, and doesnt drop to 1 like it should.<p>any ideas?<p>-Abs
Don't park drunk, accidents cause people.
92 Blaze Red MX-3 GS, KL-ZE, ACT Clutch, KL 36 ECU, SS Clutch Line
Sonicxtacy02
Re: Engine is revving?
does it do it in rhythm? If so you need to adjust/reset ur tps or iac. Search those terms for more information
Shaun Newman
yes it does do it rythmically, but not consitantly.<p>ive noticed that i idle at about 2rpm as it ism which seems a bit high to me. this revving thing only started last night, but so i havent had a lot of time to monitor it, but it doesnt seem consistent. for instance, i drove home from work on my break, and it was doing it. i drove back to work, and it wasnt.<p>how do i reset those things? do i need a mechanic to do it?<p>-Abs
Sonicxtacy02
most of the time you can do it yourself. There is a website with the full procedure on it but i cant seem to remember where on this site the link is. Its a simple procedure though and it sounds like it is what you are having problems with.
Shaun Newman
I had a similar problem a while back but it was doing it whether the clutch pedal was in or out once engine revs had dipped below a certain amount (tickover, coming to a stop, changing gear at low speeds). It turned out to be a broken throttle body. The whole unit had to replaced.
