miata cams and camgears
I read on this forum that someone has putted on their 1.6dohc, miata 1.6 90/93 cams and cam gears! is this true??? if it is , I got lot of choices of high lift cams. I just need to know if it is a perfect fit??? are any other mods to do to apply them??? try to help. excuse my english.
Re: miata cams and camgears
Many past threads posted on this topic. Here's one, http://www.mx-3.com/ubb/ultimatebb.php?ubb=get_topic;f=3;t=003192#000001 but if you do a search with words <miata cams> in the 4-Cyl. Technical/Performance Forum you'll find more than 30 other related threads...
thanks. but I would like to talk directly to someone that as already done this mod! but thanks anyway,any help is apreciated!
- Josh
i have. the only prob with Miata cams is timming, the cams will 180% out from MX 1.6L cams. so you need a timming wheel to get the timming perfect. and you can find out more info in a few of the threads.Originally posted by MX-3RR:
please try to be more specific, what do you mean with the 180% out?? how did you solved your problem??? what cam gears are you using?? and what brand are the cams and where they a perfect fit????
when I click HERE, what do I have to search for?? oh and by the way I used to spend my vacations in FORTLAUDERDALE! I remenber one store there, its SOUNDADVICE. maybe will meet next year IM making plans to go ther next year. now about my cam gears and cams, what have you got for me??
JOSH, whitch brand and kind of timing wheel should I use???
hey, jedi master.....are you there???
Search for Miata cams.
Also look up the miata forums.
I was told those guys know how to squeeze hp out of our motors.
![Welder :welder:](./images/smilies/welder.gif)
