The main problem with repeatedly posting the same thing is when you do use the seaech feature. Once something has been said over and over, the search function ignores the word because it would turn out too many results. "O2" has been ignored because people use it to discribe problems or when people are helping diagnose the problem related to the oxygen sensors. Yes, the search feature is screwed up, but as I said, only due to repeatedly posting the same thing. As Shameem said, If a word is ignored like "O2" substitute it. Granted, in some instances there are words that ignored that can't be substituted easily. (refers to bubsy83) Like what Shammem siad, it won't kill you to read through results for more than 2 seconds. Even though you might not find exactly what you are looking for, you will find other info that may be relevant to your problem. When I was looking for a color code for the interior, I spend a good amount of time reading through countless posts, it wasn't until after I read all those posts that I posted a thread asking for the code. Uncamara found the info I requested on the main page under "Interior". In that location, it could have been easily overlooked, But since I TRIED to find what I was looking for, someone was willing to help.
All you have to do is
TRY, It might take longer to find your answer, but you will also learn other things in the process, and spending only a few minutes searching and not getting the answer you require to to a
COMMON word being ignored, It DOES NOT entitle you to be spoon fed your answer, unless you're on your deathbed or something
. Even still, if you're on your deathbed, why would yu be looking up ways to fix a car
In all this ranting, this consists of FACTS anf my own opinion. (I just thought I'd clarify that.)
