323/protege cam and gears
will the camtech street cam for the 323 sohc fit the b6e? here are specs for it:<BR>camtech 1.6L 323 sohc street cam grind#2 (210 intake 210 exhaust @.050 lift .247" cam lift low-mid range 2400-6500 rpm)<P>same thing with 90-94 protege corksport camshaft set. specs:<BR>90-94 protege Cork Sport peformance camshaft set<BR>The Cork Sport performance cam set are brand new camshafts not regrinds. The specs are .352 lift and 205 duration at .050 lift for both intake and exhaust. The estimated gains on a mildy modified motor are 12 hp. <P>im sure these cams wont work well with f/i setups and should be swapped out for new ones. but im sure the hks miata cam gear works well with boosted and n/a setups. will this cam gear fit onto the b6e as well?<p>[ November 24, 2002: Message edited by: marshmallow15 ]
- team slideways
- team slideways
Re: 323/protege cam and gears
Cams for the 1.8L cars are not interchangeable with any of the 1.6L stuff. The cams are physically longer for the 1.8L, as the block is 22mm longer. (almost an inch)<P>Then youre asking if SOHC cams can fit DOHC heads?
-93 MR2
#129 E-stock
#129 E-stock
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by ProtegeSTS:<BR><STRONG>if SOHC cams can fit DOHC heads?</STRONG><HR></BLOCKQUOTE><P>what i meant was if a cam from a dohc could fit into a sohc...same with the gear and etc.
- team slideways
- team slideways
DOHC- Dual overhead cam ( two cams )<BR>SOHC- Single overhead cam ( one cam )<P>this should be almsot self expalnitory, to somone with a few cars and a show eclipse and rx7 under his belt..id hate to show up at a race and ask thant question
92 red rs
performance exhaust
zx2 struts and Eibach springs
turboed + stand alone when the cash is there
yea ryan i know that...i just meant if i used one cam and cam gear from a dohc, can that on cam/gear be used on the sohc.
- team slideways
- team slideways
I think you guys are being a little hard on marshmellow, the reason that a DOHC cam won't work is becasue the DOHC head uses one cam for exhaust valves and one for intake valves wheras the SOHC uses one cam for both. Just becasue someone has nice cars doesn't mean that they know everything about engines. Its better that he asks and finds out rather than being afraid of asking because someone is going to make fun of him.
'94 Blaze Red RS<P>I may not have a lot of horsepower but I know how to use it!
another way to look at is....<BR>DOHC 16v head has 2 cams in it:<BR>-1 cam for intake valves(has 8 lobes on it)<BR>-1 cam for exhaust valves (has 8 lobes on it)<BR>-Also utilizes 2 cam gears (1 for each cam)<P>SOHC 16v head has 1cam in it:<BR>-1 cam for intake & exhaust valves (has 16 lobes)<BR>-Only has 1 cam gear<P>As you can see both heads have 16 valves...yes they are the same in that way, but it doesn't mean the parts are interchangable because the valves are physically positioned differently in the SOHC than in the DOHC. As for using the HKS cam gear on a custom SOHC cam shaft (check out <A HREF="http://www.gude.com)" TARGET=_blank>www.gude.com)</A> I'm not sure if that would work or not. You might want to call up Derrick @ Corksport & ask that one! I'd say it won't work because they are marked to be used as a pair on the DOHC. You could SEROUSELY screw up your timing by trying it and more than likely end up bending some valves over.
tnx a lot guys thats the info i was lookin for. guess ill have to beg for custom ones.
- team slideways
- team slideways
i have access to a dohc motor...does anyone know if these will work on the dohc then?
- team slideways
- team slideways
The 1.8 cams won't work in either of the 1.6's because the 1.8 is physicaly longer. The pulleys might. If your using the 1.6 DOHC, I believe the 1.6 DOHC Miata cam gears would work the best. Call Corksport. <A HREF="http://www.corksport.com" TARGET=_blank>www.corksport.com</A>
