Radiator hoses
- MazdaRider
Radiator hoses
Is their any replacement hosese for the v6
Or are all the performane hoses universal
- icajewler
Re: Radiator hoses
I am about to get measurements of all the cooling system hoses and make a list of Samco hoses for replacement =] Not making any promises for how soon I will do this (super busy with career) but, it should happen sometime next month. Here's the link to the universal straight hoses I will be sourcing from http://www.samcosport.com/usa/rp_straight_hoses.asp
93 MX3 SE (klze conversion in progress)
03 Elantra GLS (DD)
92 MX3 GS sold
missed!
The very air around me seemed to catch fire and freeze at the same time, that's how I knew he had enough for today.
Rangers Lead The Way!
03 Elantra GLS (DD)
92 MX3 GS sold
- kulluminati777
Re: Radiator hoses
cool idea wouldnt mind hoses that last a tad bit longer on a stock application
- MazdaRider
Re: Radiator hoses
I just ordered the all aluminum radiator from silla an should be here in a week so its be best to do it some time soon
Re: Radiator hoses
last time I got mine they had to get the lower through the dealer, the upper is a straight hose just about so Im sure you could get a samco from another application that would fit.
I modify my ride so I can drive around the stupid people ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- MazdaRider
Re: Radiator hoses
Theirs a klez set up for a probe would that work ![Shrug :shrug:](./images/smilies/shrug.gif)
- icajewler
Re: Radiator hoses
I'm currently on my way to DC and won't be back till Thursday. I should be able to get measurements then. Unless someone else can give me a list of the stock hoses with inner diameter and wall thickness measurements and I can compile a list from my phone.
03 Elantra GLS (DD)
92 MX3 GS sold
missed!
03 Elantra GLS (DD)
92 MX3 GS sold
- icajewler
Re: Radiator hoses
The hoses in blue are the ones I took measurements of. Wasn't exactly the easiest thing to get numbers for, but not the hardest either. I am going to do all of the hoses under the IM when I pull the engine out. I wrote the measurements for each hose in case you want to find a different vendor to source other hoses (cheaper ones hopefully. Samco is expensive!) But for simplicity, I put the straight and XtraFlex part numbers from Samco. If I forgot anything let me know!
Happy Tuning! -icajewler
![Image](http://i1032.photobucket.com/albums/a410/icajewler/93%20Mazda%20MX3%20SE/CoolingSystem_zps4f207bde.jpeg)
03 Elantra GLS (DD)
92 MX3 GS sold
missed!
03 Elantra GLS (DD)
92 MX3 GS sold
- MazdaRider
Re: Radiator hoses
Price isn't a factor what ever I want I get ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- projectB10
Re: Radiator hoses
Hi ICA......These hoses must already exist in the SAMCO catalogue.
I have the SAMCO hoses in blue, in the fitments as numbered #4 and #5 in your post image fitted to my Eunos Presso (MX-3).
They were fitted to a JDM Mazda Lantis (2.0LV6) which I picked up second hand.
Chris
Chris
icajewler wrote:The hoses in blue are the ones I took measurements of. Wasn't exactly the easiest thing to get numbers for, but not the hardest either. I am going to do all of the hoses under the IM when I pull the engine out. I wrote the measurements for each hose in case you want to find a different vendor to source other hoses (cheaper ones hopefully. Samco is expensive!) But for simplicity, I put the straight and XtraFlex part numbers from Samco. If I forgot anything let me know!
![Image](https://www.supermotors.net/getfile/896218/fullsize/signature.jpg)
- icajewler
Re: Radiator hoses
I will try to find them!projectB10 wrote:Hi ICA......These hoses must already exist in the SAMCO catalogue.
Chris
03 Elantra GLS (DD)
92 MX3 GS sold
missed!
03 Elantra GLS (DD)
92 MX3 GS sold
- icajewler
Re: Radiator hoses
I found out by emailing them that kit number tcs395c contains three hoses and the two big ones are a direct fit. I think its numbers 4 & 5. Maybe 3 & 4. Anyway, its for a 2008 gtr. Here's the link http://www.samcosport.com/usa/car_kits.asp?make=Nissan its like 16th down the list or so.
03 Elantra GLS (DD)
92 MX3 GS sold
missed!
03 Elantra GLS (DD)
92 MX3 GS sold
- MazdaRider
Re: Radiator hoses
Theirs three hoses in the kit 2 of them for sure are from the block to the radiator can the other one be split for the side tank hanging off the radiator
