mx3_ryder wrote:I wonder if 215/45/17's are gonna be too much tire after I lower the car on ebiach's or H&R's? The roads are terrible up here in the northeastern part of Vermont so hence more rubber.
How wide are those wheels? You might need to camber a bit if the wheel+rim is too tall.
mx3_ryder wrote:
ZE is running super smooth again!! Got it timed the first attempt. Time to start the body work!! Actually have already started sanding but don't have any pics yet, will take some along the way.
I Cut 2.250" inches out of my stock shifter and welded it back together, can't even tell where the weld is.
Good stuff! Cheaper than buying a short shifter.
Yes, much cheaper and feels great combined with the new bronze bushings. I'll snap an installed pic sometime...
The first bumper I had needed to be stripped entirely because of chipping and cracking. Uh, but then I found one in my parts pile behind my house that I didn't even know I kept. Haha. This one was teal and didn't need to be stripped because the finish is perfect on this one. All I had to do was take the lip off the red bumper and put it on the teal one which was a pain. I had a hard time finding the correct plastic push rivets with philips head. When I did find them at one of the three local parts stores I grabbed a dozen of them since I would need some for the splash guards and euro skirts. I've got the bumper and hood prepped and primed and currently filling and sanding out the dents on the car. I am waiting to get a welder for Saturday so I can weld the holes that were made from sheet rock screws where the side skirts used to be. Getting there guys, should be done and painted within a month. Only have 1 day a week to work on her. Working 62 hours a week , renovating my house and getting ready for the new born.
I always get so jealous when I see people doing body/paint work... I took 2 afternoons to do a rattle-can paintjob, but I've been meaning to get a true "proper" paintjob for quite a while now.
Hey thanks man... Just need the concept, right tools and anyone can do it. Getting all the high and low spots and having a smooth transition between filler and body is key. Doesn't matter how many small coats of filler I use, I will not spray it until i've got it smooth.
The progress is coming along nicely. I would suggest painting the lip and bumper separately (if you haven't already). Heaven forbid you should crack your front lip off, but if you did,your bumper would be the correct color underneath.
Great idea Aaron. I thought of that actually because I don't want the paint and clear to crack and chip where the lip comes up againt the bumper, so yes I'm going to paint them seperate.
These are not up to date pics but just shows some of the progress I've made lately. All dents and screw holes are filled, smoothed and primed now. Gotta pick up some more high build primer and sealer and then sand for top coat. Decided I will be removing doors for the painting process along with painting pretty much everything off the car. Last couple pics shows bumper on the car cause I just had to see what it looked like. Also wanted to make sure all was well with bolting it before paint cause I had to modify some things. I will post some more up to date pics soon. Getting excited to get it done and also even more excited for the birth of my son here in a few weeks. Later...
Everyone likes pics... Bodywork complete minus a couple of small dents on the doors that I found later on and still need to be filled.
Finished and sealed quarter...
Paint was peeling on the hatch... Little compressed air took care of most of it, then just feathered it in.
The dozen or so screw holes from the previous full aftermarket sides filled, primed and sealed.
I'm liking your car. I want to get a wrap around for my car... I will also be running mini sides, flaps, and front lip. I LOVE the cleeeean factory look.
Keep up the good work, and congrats on the new addition!
