Would the spark plug wires from a mx6 work ok a Mx3?
If not are their any good ideas it their??
Spark plug wires question
- MazdaRider
- mx3_ryder
Re: Spark plug wires question
Yes they will fit. Back three wires are longer I believe but will work.
- MazdaRider
I found some 10.2mm
Mx6 wires would that be too much??
People like to use Mx-6 wires cause they're longer, so they run better. Mx-3 wires can be a little tight, especially if you want to route them around nicely.
MX-6 wires are the way to go. The MX-3 ones are crap because you have to route them over the manifold due to the length and it looks messy IMO.
1995 Eunos 30x KLZE
