This type of mod will work on the more generic strut bars (Kp2t and Deimos have it done), but the concepts are the same, it's that damn high point screw on the IM that you need to clear that's directly in-line with the strut bar. Just a few simple pieces needed.
Besides that I repainted it (getting stratched from the hood and that I didn't clear coat it) and the longer bolts, this is basically the regular setup of the CorkSport strut bar.
![Image](http://img341.imageshack.us/img341/7623/59114126ja8.jpg)
This is just the idea on what needs to be done. You can do this on a regular thin-bar strut bar as well, it moves it just enough to work. On either bar, the problem with this is that when you tighten up the bolt, it will never tighten, and the arms that hold on the bar will just squish together, voiding out the point to his mod, ruining the look of the bar itself, and have fun prying those arms apart again after.
![Image](http://img341.imageshack.us/img341/6681/63229251yo8.jpg)
![Image](http://img135.imageshack.us/img135/8899/30641598qj1.jpg)
So what you need to go is put a spacer in between the arms. We just has a piece of metal pipe was the perfect diameter to look good, just neeeded to cut it to length. On the thin-bar strut bars, you can use a piece of pipe or a solid tube of the sort, but what we did on Kp2t's is actually fit in 2 nuts in between; took a little convincing, and it was tight (which is good), but it worked.
![Image](http://img112.imageshack.us/img112/9273/56657974mg2.jpg)
![Image](http://img341.imageshack.us/img341/9715/98483797pt5.jpg)
![Image](http://img341.imageshack.us/img341/3743/22485650oh1.jpg)
And the finished mod to the bar
![Image](http://img112.imageshack.us/img112/2920/52698311cl4.jpg)
But we're not quite done yet. It's still too low. Just need to raise it up a tad, which is easy as well. You actually keep the strut bolts on. On mine, we kept just the two inner, thinking the angle would help pull it up, but I dont believe it's necessary.
![Image](http://img135.imageshack.us/img135/8290/87856156cz4.jpg)
![Image](http://img112.imageshack.us/img112/8687/83653322jr1.jpg)
Like I said, I kept the two inner bolts, but I'm fairly confident that keeping all 4 will work fine as well. I know it does on the thin-tube strut bars, but haven't had the oppertunity to try it on any other CorkSport bars.
With my strut bar on top. Just need to get a second set of nuts to bolt it up. You can get some shiny new ones, or get them for cheap/nothing from the wreckers.
![Image](http://img112.imageshack.us/img112/9209/10qh9.jpg)
The bar mounted, moved away from that pesky screw.
![Image](http://img135.imageshack.us/img135/6555/11bl9.jpg)
And the clearance underneath is tight, but works.
![Image](http://img112.imageshack.us/img112/6382/12ax7.jpg)
