rough idle and smoking
FastFlaMx3
Post by FastFlaMx3 »
ok so pulled into drive way heard a small pop and car started running rough and started smoking really bad i have a 93 1.8 164k
http://www.cardomain.com/ride/3882183" onclick="window.open(this.href);return false;
mitmaks
Re: rough idle and smoking
Post by mitmaks »
Blue smoke, white smoke? How's oil/coolant.
FastFlaMx3
white smoke oil fine collant fine
mitmaks
Post by mitmaks »
Possibly coolant leak
FastFlaMx3
well i got it back from shop rings are gone grrrr i cant affod a rebuild so im selling my mx3
MrMazda92
Post by MrMazda92 »
Don't rebuild! Swap a DE in for ~$500 with a gasket/water/oilpump job... Totally worth it!
FastFlaMx3
i dont have 500 lol
Syeemx3
Post by Syeemx3 »
Save the money even if your a broke guy you put aside 100 buck a check that 2.5months you got the money... Just hate to c you sell it...
kulluminati777
Post by kulluminati777 »
yeah dude dont sell just swap to a de in a few months or swap to a K8 which is dirt cheap just take the bus for awhile....
If you can't afford $500 to fix your car, and you're going to try to sell a car with a blow motor that won't gain ya much, how will you afford a new car? That'll probably be one in pretty bad shape.
I bought a nice condition 96 GS with some MS parts on it for $300 with a blown motor so that should give you some indication what you"ll get for your car. Doing an engine swap is the cheapest way to go for sure.
Syeemx3
Post by Syeemx3 »
KLDE more HPs more parts availible and same money as a K8 pretty much =)
