rough idle and smoking
- FastFlaMx3
ok so pulled into drive way heard a small pop and car started running rough and started smoking really bad i have a 93 1.8 164k
- mitmaks
Re: rough idle and smoking
Blue smoke, white smoke? How's oil/coolant.
- FastFlaMx3
white smoke oil fine collant fine
- mitmaks
Possibly coolant leak
- FastFlaMx3
well i got it back from shop rings are gone grrrr i cant affod a rebuild so im selling my mx3
- MrMazda92
Don't rebuild! Swap a DE in for ~$500 with a gasket/water/oilpump job... Totally worth it!
- FastFlaMx3
i dont have 500 lol
Save the money even if your a broke guy you put aside 100 buck a check that 2.5months you got the money... Just hate to c you sell it...
- kulluminati777
yeah dude dont sell just swap to a de in a few months or swap to a K8 which is dirt cheap just take the bus for awhile....
If you can't afford $500 to fix your car, and you're going to try to sell a car with a blow motor that won't gain ya much, how will you afford a new car? That'll probably be one in pretty bad shape.
I bought a nice condition 96 GS with some MS parts on it for $300 with a blown motor so that should give you some indication what you"ll get for your car. Doing an engine swap is the cheapest way to go for sure.
KLDE more HPs more parts availible and same money as a K8 pretty much =)
