Couple Questions
Couple Questions
I had a 93 Black GS which I sold (and now regretting very very much) and I was looking into getting another. Before I do however, I want to look into a few things.<P>1.) Has anyone else noticed a pool of oil that collects on the front valve cover in the GS's or was this specific to my car? If so, any remedies out there?<P>2.) Are the SE's seats still available for sale anywhere? (both front and back, but the rear is most important.)<P>3.) Did the SE's have the multi-colored inserts in the doors, or were they one solid color to match the seats? <P>Thanks<BR>Ryan Wilcox
Re: Couple Questions
i used to have oil build up. are your seals blown? Pull out your plug from the valve cover and see if there is oil all over it. I had that. It cost me alot of cash to get my engine resealed.<P>------------------<BR>Edgar Paredes
i had the same problem. you need to replace your valve cover gaskets and probably your spark plugs. it cost me about $400 usd to do that. it seems common with the k series v6's. hope this helps.<P>------------------<BR>Ray<BR>'92 GS <BR>tharaynman@aol.com
